Hello,
So I need your help with the fan setup on my case.
I recently got a phanteks Enthoo Pro, it comes with a 200mm on front (PH-F200SP) and a 120mm(PH-F140SP) on the back.
I removed the 120mm one because I have a Corsair hydro 80i gt, and i've put the radiator on the back, with fan on exhaust.
From my previously build i have 4 Noctua NF-A14 PWN, so my question is, should I remove the front 200mm fan and put it on top, and 2 Noctua on the front? And should i connect them all the pwn hub?
Thanks in advance, and sorry for bad english (not main language).
