I have the Ml 120 pro case fans and i would like to hook up 8 of them to my 4 PWM fan headers but I would need a splitter. Does anyone know if there would be enough voltage for the fans magnetic levitation bearings with the splitter?
It will draw 12V no matter how many fans u have connected to 1 header. Only current will be higher. U should read your motherboards manual, usually they can provide 1A, check how much ML fans will draw and multiply it with 2. So if u get under 1A u are totally fine.
If you take a peek at this http://www.corsair.com/en-us/ml120-pro-led-white-120mm-premium-magnetic-levitation-fan, which seems like a typical fan it draws 0.299 A. So 3 on a header that supports 1 A would definitely max it out.
