G
Guest
Guest
Archived from groups: alt.comp.periphs.webcam (More info?)
Hi.
I have an Axis 2120 that has to have its software reloaded using the
serial cable after a power outage. The thing will not reset using the
buttons on the front and back of the unit.
I called Axis Tech support and posted on their support page. The techs
told me that it was likely the internal battery for the unit. Well,
they don't have a diagram or any idea what battery the 2120 takes.
Anyone here opened up their 2120? Does anyone know what battery the
thing needs?
Thanks!
Saul
Hi.
thing needs?
Thanks!
Saul
