Question Help with finding what PSU I have
Aug 28, 2022
18
I am unable to find what power supply I have because I threw away the manual when i bought my PC, and there is no sticker with the model number of my computer anywhere. I really need to know because I will hopefully get a 3060 Ti and I don't want crashes or anything due to weak PSU.
There should be a sticker on every computer power supply which will have manufacturer and technical specifications. You would need to open up your PC to find that as it would be on the side of the power supply itself and is unlikely to be visible otherwise.
Take the side panel of the case, take a picture of the PSU and post the pictures in this topic.
Maybe the sticker is en top of the PSU. To see the label you have to take out the PSU but you have to take it out anyway if the PSU is trash.
