Help with finishing PC build
Ajdee6
20
I think I have my final build. I need to know if everything matches up, and if there is anything I should add/change? I am planning on eventually adding another 970 and am not too sure if overclocking will even be needed.
Motherboard ASRock Z97 Extreme6
CPU Intel Core i5-4690K
CPU Cooler Cooler Master Hyper 212 EVO
GPU GIGABYTE GV-N970G1 GTX 970
SSD Crucial mx100 256 GB internal
RAM Corsair Vengeance Pro 8GB
PSU Rosewill PHOTON-750
Case Antec Nine Hundred Mid
No I dont have the O.S, I am planning on using the trial version for a couple weeks until I could buy one, that way I do not have to go lower on any of the hardware right now. My max budet is $1200
I do have an optical drive and a 750GB HDD
Would 600W PSU support this system and then eventually dual 970s?
What do you think about that case? I am willing to go up to $150 for a case if its really good and looks good. I have been looking at the NZXTs and the Phanton 410 and the pricier H440 really stick out. I would prefer to keep it under $100, but those cases that go over $100 look so amazing. I like a side window and the mobo I am getting is blue so I would prefer it to at least be all black or black and blue. The PSU I am getting is about $90, so even if I can get a great case with a PSU that would go with this system for $200 - $250.
check out the corsair 450D if you want an alternative case option, otherwise the phantom series and the h440 are both oustanding cases. also the fractal design r5 is another good shout.
no 600W will not be enough for 970 SLI. It's just the rosewell photon is the bad model. The rosewell Capstone 750W is the high quality psu you want: http://pcpartpicker.com/part/rosewill-power-supply-capstone750
otherwise you're build looks perfectly fine.
Happy Building.
Thank you I switched the PSU and am going with the 450D
I cant get the H440 as much as I want it, no optical drive space, and I need an optical drive with my 3mbs shitty DSL connection.
The 450D looks really amazing, looks like it will last me a while. It takes 2 140mm fans on top and 2 120mm on the bottom, I would like at least 1 on top and 1 on the bottom for now.
What are some good case fans?
I guess I am done. Is there any idea of how much Windows 10 will cost? I am planning on using the preview build and then buying it but if 8.1 is cheaper I mind as well get that.
I dont want to pay $100 for it now, if I do I have to lower my specs and would rather not do that. Ill use the preview build though and get whichever 1 is cheaper as soon as I can. I am done thank you guys for the help.
