Help with first build
PapiTheGod
4
DIYPC Mirage-D1-W Black/White SECC USB3.0 ATX Mid Tower Computer Case with 3 x 120mm White Fans (Pre-Installed)
$49.89 -$14.00 Instant $35.89
GIGABYTE GA-78LMT-USB3 (rev. 6.0) AM3+ AMD 760G + SB710 USB 3.0 HDMI Micro ATX AMD Motherboard
$69.99 -$11.00 Instant $58.99
CORSAIR CXM series CX500M 500W ATX12V v2.3 SLI Ready CrossFire Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
$69.99 -$30.00 Instant $39.99
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop
$36.99
AMD FX-6300 Vishera 6-Core 3.5 GHz (4.1 GHz Turbo) Socket AM3+ 95W FD6300WMHKBOX Desktop Processor
$109.99
PowerColor Radeon R9 270 DirectX 11.2 AXR9 270 2GBD5-DHEV2 2GB 256-Bit GDDR5 PCI Express 3.0 CrossFireX Support ATX Video Card
$119.99 -$10.00 Instant $109.99
Subtotal: $391.84
My budget is $450 but I want to keep it as low as possible but still be able to get 60 fps on most games medium to high settings I'll be playing at 1366x768p any changes I should make? Feel free to max out my budget as long as its worth it
Note: I do have a
Compaq 6005 pro to take parts from as needed it doesn't have much besides a HDD.
your better off with and intel i3 haswell or skylake cpu and mb combo. with the intel mb you can drop in a faster cpu if needed the 6300 chip been dead for years and the newer zen chip wont be out for a bit. the cx power supply not a good unit and would replace it. look at the evga 600b/700b when there on sale or a rebranded seasonic like xfx. as your going to game save up a little more money for a newer 960ti or the newer 380 when there on sale. a lot of the 380 whe nthere on sale end up at 150.00 price points.
http://pcpartpicker.com/part/xfx-video-card-r9380p2255
wiith the newer intel mn they have the m2 sata and faster sata controllers then your mb you picked out so when you add a ssd the boot time is 3-10 sec.
you should get a ATX motherboard, not micro, cause in the future you can use it for more features, such having 2 graphics cards run at the same time, more ram, more fan headers, more overall features.
i suggest this board
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130849&cm_re=am3%2b_motherbaord-_-13-130-849-_-Product
You will end up with $480 if you go with the 2 parts i suggested.
and if your willing to go abit over your budget you can get a better Graphics card like the GTX950
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127904&cm_re=gtx950-_-14-127-904-_-Product
I say you go abit over your budget get that motherbaord and this 950.
