Hey
this is my first ground up build, and it will also be my first OC try.
i was hoping for some good tips, and anything i should avoid.
if you have a setup close to this, and have some multiplier/voltage ratings for me
that would be great as well.
My setup is:
AMD|A64 X2 5000+
ZALMAN CNPS 9500
SAPPHIRE 100225L HD3870
2x1gb CORSAIR Dominator 1066
GIGABYTE GA-MA770-DS3 mobo
I am running a raidmax case with three 80mm and two 120mm fans
as well as a raidmax 500w psu.
THANKS!!!
this is my first ground up build, and it will also be my first OC try.i was hoping for some good tips, and anything i should avoid.
My setup is:
AMD|A64 X2 5000+
ZALMAN CNPS 9500
THANKS!!!
