Hi all,
I am wondering if anyone can shed some light on which one of these will be compatible with a single Xeon E5-2697 v2 12-core, I've been told either one of these two should work?:
COOLER MASTER Hyper 212 EVO CPU Cooler
www.newegg.com/Product/Product.aspx?Item=N82E16835103099
Dynatron T318 135 Watts Vapor Chamber CPU Cooler
http://www.newegg.com/Product/Product.aspx?Item=N82E16835114132
Also I'm hoping someone experienced can have a look at this list to see if there are any incompatible components? I'm really happy with the Tower, Motherboard, CPU and GPU choice. And I'll be adding another Xeon + three more GTX Titans to this as I can afford it:
1 x Corsair Obsidian Series 900D Case/Tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139019
1 x SILVERSTONE ST1500 1500W Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256054&Tpk=silverstone 1500w
1 x ASUS Z9PE-D8 WS Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131817
1 x Intel Xeon E5-2697 v2 2.7GHz 12-Core CPU
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116925
1 x Crucial 32GB Kit (16GBx2), DDR3 1600MHz ECC RAM
http://www.crucial.com/store/mpartspecs.aspx?mtbpoid=21D787CFA5CA7304
2 x EVGA GeForce GTX TITAN SuperClocked 6GB SLI Ready
www.newegg.com/Product/Product.aspx?Item=N82E16814130899
1 x StarTech 4 PCI Ex PCIe SuperSpeed USB 3.0 Controller
http://www.newegg.com/Product/Product.aspx?Item=N82E16815158362
1 x Rosewill N900PCE Wireless Dual Band Adapter PCI Express
www.newegg.com/Product/Product.aspx?Item=33-166-076
1 x ICY DOCK 2.5" to 3.5" SATA 6Gb SSD Converter (for my 2.5" Vertex SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817994064
1 x AFT PRO-55U All-in-one USB 2.0 Card Reader
http://www.newegg.com/Product/Product.aspx?Item=N82E16820176021
1 x ASUS Black Blu-Ray Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135306
1 x Arctic Silver 5 Thermal Compound
http://www.newegg.com/Product/Product.aspx?Item=35-100-007
2 x Tower Interior Light
http://www.newegg.com/Product/Product.aspx?Item=N82E16811994001
1 x Zip Ties
http://www.newegg.com/Product/Product.aspx?Item=N82E16899997047
1 x ORICO 1M Velcro Cable Tie
http://www.newegg.com/Product/Product.aspx?Item=9SIA1DS0JG1923
Any help is greatly appreciated!
1 x Zip Ties
