P Prorex0 Reputable Aug 2, 2015 51 0 4,630 Sep 18, 2015 #1 i recently update 2 windows 10 and i found my fps in games dropped so i went back to win7 but i still have those same fps. is there something i can do to fix this? Thank You
L Long__T123 Reputable Sep 18, 2015 147 0 4,710 Sep 18, 2015 #2 Reinstall drivers. You need to give us more about the problem. I can't help you with very little info Upvote 0 Downvote
P Prorex0 Reputable Aug 2, 2015 51 0 4,630 Sep 18, 2015 #3 Long__T123 : Reinstall drivers. You need to give us more about the problem. I can't help you with very little info what kind of more info pls tell me so i can provide Upvote 0 Downvote
L Long__T123 Reputable Sep 18, 2015 147 0 4,710 Sep 18, 2015 #4 What game are you playing and your specs Upvote 0 Downvote
P Prorex0 Reputable Aug 2, 2015 51 0 4,630 Sep 18, 2015 #5 Long__T123 : What game are you playing and your specs witcher 3 i used 2 get 40-45 not im gettign 30-40 Upvote 0 Downvote
L Long__T123 Reputable Sep 18, 2015 147 0 4,710 Sep 18, 2015 #6 What are your system specs? is the gameworks setting on? Upvote 0 Downvote
P Prorex0 Reputable Aug 2, 2015 51 0 4,630 Sep 18, 2015 #7 Long__T123 : What are your system specs? is the gameworks setting on? a8 6600k, gtx 750 ti all the nvidia things are off and its on high ultra midums settigns Upvote 0 Downvote
L Long__T123 Reputable Sep 18, 2015 147 0 4,710 Sep 18, 2015 #8 It seems like you have a HHD. try to defrag it. When you put windows 10 on there, I bet that a lot of things got fragmented. Upvote 0 Downvote
P Prorex0 Reputable Aug 2, 2015 51 0 4,630 Sep 18, 2015 #9 Long__T123 : It seems like you have a HHD. try to defrag it. When you put windows 10 on there, I bet that a lot of things got fragmented. allright ill try that and update Upvote 0 Downvote
L Long__T123 Reputable Sep 18, 2015 147 0 4,710 Sep 18, 2015 #10 hhd can affect fps in open world games if it is very fragmented, especially minecraft and gta v, since the world is constantly loading as you move Upvote 0 Downvote
