Help with front panel cables
christapia54
13
Where do i plug in these cables im having a difficult time i dont understand it on the manual my motherboard is an ASUS z170 e the case im using is this Rosewill ATX Mid Tower Gaming Computer Case, Tempered Glass Panels, Up to 420mm GPU, 360mm Liquid-cooling, 4 120mm Fans Pre-installed - CULLINAN https://www.amazon.com/dp/B01M6TV6PC/ref=cm_sw_r_cp_api_1bQ9zbMC2TZDG
The cables say
RESET SW +-
POWER SW+-
POWER LED+
POWER LED-
H.D.DLED +-
Motherboard Manual Pg. 1-31.
With the Pin layout as below, make the following connections
2 4 6 8
1 3 5 7 9
Reset SW + in Pin 7
Reset SW - in Pin 8
Power SW + in Pin 5
Power SW - in Pin 6
Power LED + in Pin 2
Power LED - in Pin 4
H.D.D. LED + in Pin 1
H.D.D. LED - in Pin 3
-Wolf sends
Latest posts
