Help With Game Set up. (Pros Only) Reward for help
Pc Noob Plz Help
26
https://www.draw.io/#LUntitled%20Diagram.xml
I have designed a digram for you to check out of my plan ^^^^^^^^^^^^^^^^
The audio for the tv will have an audio receiver
Here are the links for the monitor,Surround sound, and pc speakers. So you can see the inputs and output options I have
Monitor:http://us.aoc.com/monitor_displays/g2770pqu
Pc speakers:http://www.logitech.com/en-gb/product/surround-sound-speakers-z506
Tv surround:http://www.amazon.com/Yamaha-YHT-399UBL-Channel-Theater-System/dp/B00BW0X6EE
Now here is the problem....
The xbox is connect via splitter between the tv and monitor how do i control sound outputs? So say if I want to game on my tv and kick back how will i get it to use the tv surround sound instead of the pc surround? Manythanks this has been a big big problem for me and valid help will be great, I even have a spare £30 amazon gift card lying about so I can give that away for the best help because this problem has been with my for days, I cant sleep lool.
All i Know is I might need i ton of optical splitters, optical switches, hdmi switches, hdmi splitters
I also plan to record gameplay with and elgato hd 60 soon so any extra ideas on how to connect this with my set up will be good
And i also plan to add a ps4 later but thats just gonna go straight to the 40 inch tv and would be connected to the surround sound so that okay no splitter will be running through it or anything.
I have my pc setup on a 50" LG 3d display.... I sue hdmi to connect and run my sound through my video card.... it then goes to my tv and whatever audio device is connected to it... you can use a splitter to connect it to the two devices, but can cause issue with the pc hardware identification system... and running it as two monitors will somewhat degrade performance.
can you please explain in detail but using my situation many thanks
