Help with gaming PC build
arcanix
5
So I want to create my own gaming PC but I'm not really sure if the hardware components fit together, etc. These are the specs I've found so far:
Case: NZXT S340
Motherboard: GigaByte GA-Z97X-Gaming 5
CPU: Intel I7-4790K 4GHz 8M
GPU: Gigabyte GTX970 4GB WINDFORCE
RAM: DDR3 2x4GB/2400MHz Kingston
PSU: Corsair VS650W
HDD: Sata3 3,5" 1TB Seagate
My question is: Will this build make a good gaming PC? Thanks in advance.
With that kind of budget, you can build almost whatever you want.
If you are unconcerned about overclocking, a Xeon E3-1231 V3 and an H97 motherboard could save you about $100 that could be put towards a 980/Ti or Fury X.
A SSD is also a must with that kind of budget.
This information is rather important. Do you intend to overclock?
That PSU is of questionable quality. Stick with EVGA or XFX atm.
Maybe some time in the future if I want the performance increased a little bit
This is well in your budget, and has everything you'll need for gaming for quite a long time.
CPU: Intel Core i5-4690 3.5GHz Quad-Core Processor ($217.99 @ NCIX US)
Motherboard: ASRock H97 PRO4 ATX LGA1150 Motherboard ($89.66 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1866 Memory ($49.99 @ Newegg)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($108.36 @ Amazon)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($124.99 @ Amazon)
Video Card: EVGA GeForce GTX 980 Ti 6GB Video Card ($649.99 @ Amazon)
Case: Corsair SPEC-01 RED ATX Mid Tower Case ($44.99 @ Newegg)
Power Supply: EVGA 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($104.99 @ NCIX US)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer ($12.99 @ Newegg)
Operating System: Microsoft Windows 7 Home Premium SP1 OEM (64-bit) ($89.91 @ NCIX US)
Total: $1493.86
Generated by PCPartPicker 2015-06-26 17:58 EDT-0400
Thanks! Appreciate the answer
