[SOLVED] Help with Graphic Card
Mar 28, 2019
5
Ok so I finally have my build and now i need to decide wich GPU to buy, im between MSI GeForce GTX 1660 Ti 6GB GAMING X and RTX 2060. I will be playing in 1080p 60Hz at the moment because that's the monitor i have but i do want to buy a 2K monitor someday.
https://pcpartpicker.com/list/HPV2yX
What do you think about my build? Some changes? Help me to decide wich Graphic Card to buy!
Thank you
Good looking build. I would go with the RTX 2060 if you want to squeeze every fps out of a GPU. The 2060 has a slight bump on the 1660 Ti in performance (~20%). It also has the ability to do ray-tracing. Although the 2060 may be too weak to do it smoothly.
Will the seasonic 550W gold be enough power if I buy the RTX 2060?
