Help with graphics card issue
PlzneedHelp
Commendable
Mar 8, 2016
5
So i have a gt-740 bad yes i know anyway i was just browsing youtube when i see nigida driver update so i press update it downloads and updates . after a while chrome starts to crash then my pc crashed and when i try to start igoes to the login screen i log in and freezes when i enter my password . Anyone got any solutions?
Ive always used DDU uninstaller when I've had driver issues. Start in safe mode and run it - then put the new nvidia drivers on.
-Bruce
hxxp://www.wagnardmobile.com/forums/viewtopic.php?f=5&t=183#p565
This is not a live link - replace xx Also just click on Official download.
1)Uninstall current driver
2)Install newest driver from Nvidia, you want a program to do it automatically, download GEFORCE EXPERIENCE and use "clean installation"
I'm sure the problem is happening because you "updated" the driver but you didn't uninstall the previous one, so you have 2 drivers installed causing conflict or something
How does one install it when the screen freezes when i enter my password. it says welcome and the spinning wheel just stops and i cant press or do anything
-Bruce
Okay so i have downloaded the program on a usb but how can i run on he pc.? because like i said the graphics card freezes the picture at the welcome screen just stops and does nothing
sweet got it working thanks for the solution mate much appreciated
