Help with graphics
treowe
Hi, I recently got another pc with an integrated graphics card for my Sims 2. I don't know if it's a piece of doodoo or just not set correctly, but the graphics are awful. :heink:
My old pc has a Radeon 9600, and I wanted better graphics on the new pc but was told that the integrated card should be just fine.
The specs are:
Intel(R) Graphics Media Accelerator Driver Report
Report Date: 07/01/2009
Report Time[hr:mm:ss]: 10:25:54
Driver Version: 6.14.10.4906
Operating System: Windows XP* Professional, Service Pack 3 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 3317 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 384 MB
Graphics Memory in Use: 11 MB
Processor: x86 family 6 Model 23 Stepping 10
Processor Speed: 2982 MHZ
Vendor ID: 8086
Device ID: 2982
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Intel(R) G35 Express Chipset Family
Video BIOS: 1594.0
Current Graphics Mode: 1280 by 1024 True Color
I don't know if this is a good set up for Sims 2, and wonder if there is a way to change/tweek the settings for optimal graphic performance in my game.
thanks for any advice
Sims 2 is not that graphically demanding (relatively), but you should still get at least a low-end graphics card to play things smoothly. Check newegg.com for a good cheap graphics card. Something like an HD 4550 is fine, although for your needs the possibilities are endless.
I've read that too, but I wasn't really satisfied with the graphics of the 9600, it just wasn't clear enough and I need to be able to take nice clear screenies.
Bwa ha ha.
Yeah, that integrated graphics is worse than your old Radeon 9600. Go to newegg.com and get either an nvidia 8600GT or a 9500GT. Whichever is cheaper. Those cards a pretty low end, but they should be more than enough for sims2
