Help with gtx 770
naeryndam
Hello I just bought a computer from a local computer store and it has a gtx 770 gpu in it. The problem I'm having is it has a VGA DVI and HDMI output in that order and i can't seem to find a gtx 770 that has that. I did it direct x diagnosis and indeed it says gtx 770 4 gb gpu. I just would like to know if this is counterfeit or if there is a brand out there that makes them with Vga still
With the GeForce GTX 770 you will receive four display connectors, you'll spot a full size Display port connector, one full size HDMI connector and two DVI connectors (dual-link). You can combine these connectors to setup a surround view (multi-monitor) setup. One card will give you more than sufficient performance to play your games on three monitors. To date we still receive this question a lot, but dual-link DVI does not mean you can hook up two monitors to one connector.
