Help with hardware/motherboard compatibility
Uraneum
12
So I've decided to upgrade my mobo, processor, and RAM (from DDR3 to DDR4 to fit the new mobo), and I'll also be hooking up an aftermarket CPU fan. Before I drop $500-$600 I want to be absolutely sure that these parts will be compatible. I've done a good deal of reading and I think they should all work fine, but I figured I'd post here and ask for any observations from someone more knowledgeable.
I know I'm basically asking for someone to hold my hand, and I'd be totally fine if nobody bothered to answer this, but I figured I'd give it a shot. Here are the parts I'm buying along with my current hardware that I'll be hooking up to it:
New parts:
Motherboard:
https://www.amazon.com/dp/B012IBPPWG/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23P34AL931XR5&coliid=I4O15TF3JKDZH&psc=1
CPU: https://www.amazon.com/dp/B012M8LXQW/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23P34AL931XR5&coliid=I3AKOHK4OVYS2A&psc=1
CPU Cooling:
https://www.amazon.com/dp/B0080ATR2Y/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23P34AL931XR5&coliid=IKUSVZJTFPRT9&psc=1
RAM: https://www.amazon.com/dp/B00TY6A1P0/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=23P34AL931XR5&coliid=I1XWBA8S288RJJ&psc=1
Current parts that I'll be using:
GPU:
https://www.amazon.com/gp/product/B00ZGF0VGC/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
PSU:
https://www.amazon.com/gp/product/B00ALK3KEM/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1
Any insight would be appreciated. I know I'm asking about something that should be basically trivial, but I've never replaced a motherboard before and despite my reading, I'm not quite 100% sure everything will work.
Your build is a little bit unballanced. First of all, if you spend that much on the motherboard and overclockable CPU, then you should get a better CPU fan. If you get that motherboard then get a faster DDR4 RAM running at 3000Mhz CL15 or 3200Mhz CL16, and get 16 GB of it, 2x8GB sticks, don't get 2x4GB, it sucks and less room for upgrading later on.
I would suggest you to save some money on motherboard, get one with h170 chipset for less than 100$ because you are paying for features you most likely don't need, also if you won't be overclocking then get 6700 non K CPU, it's good value, if you are getting these then RAM can be 2400 Mhz or depends on what maximum speed the motherboard supports.
PCPartPicker part list / Price...
CPU: Intel Core i7-6700 3.4GHz Quad-Core Processor ($303.77 @ OutletPC)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($24.99 @ Newegg)
Motherboard: Gigabyte GA-H170M-D3H Micro ATX LGA1151 Motherboard ($87.99 @ SuperBiiz)
Memory: GeIL EVO POTENZA 16GB (2 x 8GB) DDR4-2133 Memory ($72.99 @ Newegg)
Total: $489.74
Generated by PCPartPicker 2016-12-06 17:12 EST-0500
Thanks for the feedback, goes to show I don't know jack about motherboards. I think I'm gonna take a look at those parts you listed instead. I really appreciate the help.
