Build Advice Help with input to improve build
MYMIXTAPEISHOT
Hi all,
I have the following build and was wondering what if any little improvements can be done
MB: Gigabyte GA-78LMT-S2P
CPU: AMD FX4300 quad core (3.8gh?)
RAM: 16gb DDR3 GSkill Ares Series 2400
GPU: XFS AMD Radeon RX 6500 XT 4gb
Windows 10, 64bit
Not sure the power supply
Hard wired in
It is used for light gaming nothing special other than games so far so good, system play never winder and other games like such just fine I think my visual issue is the old Asus 24” 64 hz out of date monitor.
We need to know what you're working with. Please include the make and model of the unit as well as it's age.
You're going to have to perform an overhaul of the build.
Make and model of your chassis?
What sort of a budget do you have to work with and what sort of tasks(apps/game titles) will you be taxing the system, post-upgrades, with?
Hi all,
Windows 10, 64bit
Hard wired in
Depends on budget. You're on a decade-old platform, which is effectively a dead end if you want a significant upgrade.
What do you mean by "hard wired in?" And in case, being sure of the PSU will be required to give any specific answer, so I would open it up; this is crucial safety information that you should know.
