[SOLVED] Help with installing 8 RGB Fans
avtars1404
7
Hi,
I'm going to build my first gaming pc with full custom water cooling by using all Hydro Series products, please have look https://www.corsair.com/ww/en/custom-cooling-configurator?configCode=afp6oB
Now, as you see there are total 4 LL140 and 3 LL120 fans and I going to use one more LL140 fan at rear so there are total 8 fans. My concern is how do I connect all these fans and sync with iCue? Both lightening node pro and commander pro comer with 6 ports. Do I have to buy two 'either lightening node pro or commander pro for connecting and powering all the fans or there is any other solution like by using any kind of splitter or something else. In case of using two 'either lightening node pro or commander pro, can I pair them together?
Please guide me how do I proceed from here.
Thank you.
well if u stick with iCue, then there is wiring diagram on Corsair site on how to connect more fans and rgb strips
