Help with Intel build around GTX 780 in $1200 range
moldyglint
44
Basically I am looking to build a PC (I like Intel) revolving around a single GTX 780 to run games at high/ultra 1080p with no bottlenecks in the $1200 range ($1400 is max). Haven't read up on new parts in a few years so I'm a little lost on the components to buy.. Would love to get liquid cooling on CPU and maybe even an SSD if you can make the price work. (I already have a HAF case.) Any and all help is appreciated!
PCPartPicker part list: http://pcpartpicker.com/p/PshmNG
Price breakdown by merchant: http://pcpartpicker.com/p/PshmNG/by_merchant/
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.00 @ Amazon)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($94.99 @ Amazon)
Motherboard: Asus Z97-A ATX LGA1150 Motherboard ($144.99 @ Amazon)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($76.50 @ Newegg)
Storage: Samsung 840 EVO 120GB 2.5" Solid State Drive ($84.99 @ NCIX US)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($59.99 @ Newegg)
Video Card: Sapphire Radeon R9 290 4GB Tri-X Video Card ($399.99 @ Newegg)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified...
Power Supply: EVGA SuperNOVA NEX 750W 80+ Gold Certified Fully-Modular ATX Power Supply ($86.66 @ Newegg)
Optical Drive: Asus DRW-24B1ST/BLK/B/AS DVD/CD Writer ($19.98 @ OutletPC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) ($84.98 @ OutletPC)
Total: $1272.07
I picked the R9-290 over the 780 as it performs the same and for much cheaper.
PCPartPicker part list: http://pcpartpicker.com/p/2N6qrH
Price breakdown by merchant: http://pcpartpicker.com/p/2N6qrH/by_merchant/
Motherboard: ASRock Z97 EXTREME4 ATX LGA1150 Motherboard ($128.99 @ Newegg)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($87.31 @ OutletPC)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive ($51.98 @ OutletPC)
Case: Corsair 450D ATX Mid Tower Case ($99.99 @ Newegg)
Power Supply: XFX TS 550W 80+ Bronze Certified ATX Power Supply ($69.99 @ Newegg)
Optical Drive: LG GH24NSB0 DVD/CD Writer ($14.99 @ NCIX US)
Total: $1337.20
Generated by PCPartPicker 2014-08-13 16:31 EDT-0400
I chose the R9 290 because it performs the same as the 780 and it is cheaper. :)
Wow,exactly the same build. 😛
Great minds think alike 😀
The HAF case isn't compatible with a GPU longer than 270mm.I chose the 450D case.Thats why my build is a bit more expensive than TopLuca's is. :)
What HAF ?
Do you have .....
OS ?
Keyboard ?
Mouse ?
Monitor ?
PCPartPicker part list: http://pcpartpicker.com/p/4N6qrH
Price breakdown by merchant: http://pcpartpicker.com/p/4N6qrH/by_merchant/
Motherboard: MSI Z97-G45 Gaming ATX LGA1150 Motherboard ($128.98 @ SuperBiiz)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-2133 Memory ($89.99 @ Newegg)
Storage: Seagate 2TB 3.5" 7200RPM Hybrid Internal Hard Drive ($113.00 @ Amazon)
Video Card: MSI GeForce GTX 780 3GB TWIN FROZR Video Card ($449.99 @ Newegg)
Power Supply: EVGA 850W 80+ Gold Certified Fully-Modular ATX Power Supply ($109.99 @ NCIX US)
Total: $1130.93
Generated by PCPartPicker 2014-08-13 16:24 EDT-0400
Left cooler out on purpose.....
What do you mean by liquid cooling ? Are we talking CLC / AIO ?
1. There is no 120/140mm AIO that can Match any of the better air coolers. Why spend $80 - $95 on one of those when a $65 air cooler will:
-Cool better
-Run quieter
-Won't do this http://www.overclock.net/t/1440506/my-corsair-h60-exploded-water-explosion
Ooops... it's $75 this week
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709001
2. Moving up to 240/280 mm AIOs the ones that beat the air coolers need to run fans at 2700 rpm to do so producing modern vacuum cleaner like sounds ..... in excess of 60 dbA . The better ones like The Corsair H110 will match a Noctua DH-14 / Phanteks PH-TC14-PE in cooling. And again, these are $110 and up against the $75 air coolers. Listen to a 2700 rpm cooler (H100i here:
http://martinsliquidlab.org/2013/03/12/swiftech-h220-vs-corsair-h100i-noise-testing/
I can't sit in the same room with one
3. The next step below a custom water loop is an OLC or "open loop cooler", These are just like closed loop coolers, except that sometime in the future, you can "open the loop" and water cool your GFX cards, MoBo blocks and whatever strikes ya fancy/ The Swiftech 220-X should run about $130 on newegg .... now $140 on Swiftech site.....crushes and AIO and does it 20 dbA quister.
As to the why's....
Biggest thing is "No SSD".... The hybrid Seagate will boot in 16.5 seconds compared to a top SSDs 15.6 .... you won't miss it. We have two identical machines and no one can tell the difference which has the HD + SSD and which has the SSHD. And when peeps try to squeeze both into a tight budget, since all the games are on the HD and they generally wind up with something horrendously slow like the WD Blue (ranked 63rd on THGs HD list)..... look where the SSHD (1st) is and look where the Blue is (63rd)
http://www.tomshardware.com/charts/hdd-charts-2013/-17-PCMark-7-Gaming,2915.html
If ya can squeeze the $100, I'd get the i7 .... forget the HT argument, the 4790k runs at 4.4 Ghz to the 4690k's 3.9 Ghz
Your buying a cooler so I can only assume you are overclocking ..... when overclocked, only one thing beats the 780 and that's the 780 Ti. See how the OC'd 290x compares with the OC'd 780 here:
https://www.youtube.com/watch?v=djvZaHHU4I8
yes, ya prolly never heard of EVGA PSU's but the G2 and P2 are near perfect .... other versions not so much. And the 850 watts is for when ya add the 2nd one in SLI
If that's the case, he's just fine with most 780's or 780 Tis..... BTW, can buy an Asus or MSI 780 Ti if ya shop around at the right time for $600. MSI one is the better one (9.9 techpowerup rating)
It's the HAF 922 I had from a couple years ago. I don't have OS or keyboard or any of the accessories, that's more of a side thing I'm figuring out, just needed help with the main build. And I think I'll take your advice with that air cooler. Scared me a little with that water explosion haha. As for the $100 extra for the other cpu, will that be a noticeable difference?
A Sapphire R9 290 is a better choice,since it's cheaper and it performs exactly the same as a 780 would.
I think it can,but you will need to remove some drive bays (if that's possible with the HAF 922) in order to fit a GTX 780 or a R9 290.
Don't get the Zotac.I would get the Gigabyte GTX 780 or Sapphire R9 290 Tri-X.
Okay, I was just wondering about the Zotac because $600 for a 780 Ti seemed like a bit of a steal.
zotac is the cheapest and the least performing of the 780 ti's nevertheless, it's still a 780 ti :)
They were one of the first manufacturer's to release a aftermarket 780 ti along with inno3d and evga, their reviews are quite good and you can remove the cooler to liquid cool it using a nzxt g10, but it is still better than the top performing 780, not overclocked.
1. The Tri X is cheaper, Vapor X is the same
2. The Tri-X won't fit at 12" long (922 fits up to 11.8"), vapor X is 12.2"
3. Overclocked the 780 beats not only the 290 but 290x
The Zotac is $650 on newegg, Asus is $596 (6% off w/ promo code HWSPFV78 and $20 MIR) and the MSI which is the highest rated has been $600 every other week for the last 12 weeks.
http://www.techpowerup.com/reviews/MSI/GTX_780_Ti_Gaming/29.html
This guy knows his sh*t ^
This should answer your question
index.php
Also this video
https://www.youtube.com/watch?v=R5lAbnPml4o
I have both ...... both in SLI boxes
-Thermally Phanteks does better
-Acoustically they about the same
-Phanteks is way better looking (black, white , red, blue and orange choices .... I hadda pant the Silver Arrrow fans .... no not quite as fugly as the Noctua tho
-pricewise Phanteks is lowest .... went up $10 this week.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835709011
Some new ones to look at are the Nocua DH-15 and the Cryorig R1
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF1H68938
I generally stick to the Big 4. Used to go Asus > MSI . Gigabyte > EVGA ..... now it's more like MSI >Asus > Gigabyte > EVGA
MSI is just so much quieter than everyone else and keep scoring the best OCs. The Zotac's are generally larger than everyone else.
The MSI is 10.5" and it's been $600 every other week now for about 14 weeks....and with the 880 dropping - 2 -6 weeks, I gotta expect some major sales very soon..... and rumor has it, it will come with the 7xx hi end cards will come w/ Witcher 3
