Jailbroke my iPad 4 a while ago... I tried restoring it to factory settings as it was getting slow and I wanted to upgrade the iOS Version. I tried resetting it without iTunes and I completely messed it up.... Help? When I started the restore it went to the regular loading screen that you see when upgrading iOS or resetting your Apple device. It sat for hours at the same screen without moving at ALL.
Here's what I've tried so far:
-Hard Reboot (Holding Lock and Home Button till it shuts off) then turning it on
-Trying to restore with iTunes (Failed 4 times)
-Trying to Re-Jailbreak it. (Go ahead let your giggle out)
http://gyazo.com/2f37da1452bf9e2b3c326415b96b91ce
That's the screen it's stuck on. (The loading bar is at the begging, not end)
If you need anymore info just let me now and i'll get back to you asap
