List of relevant parts:
-Lian li lancool 2
- asus tuf gaming x570 plus wifi board
-Masterwatt 750w semi modular, 80+ bronze psu
Once I finished the build I connected the 3 pin ( addressable) rgb female cable to the correspondent 3 pim connector on the board. I turned on the power everything worked except for the front panel rgb. I’ve been trying to find a solution to no avail. Has anybody else encountered this problem, if so have you found a solution? Please help.
Also I’m not sure how much this matters but my motherboard has a 12 pin (4+8) connector for the CPU; my PSU corresponding cable only has an 8 pin connector only 4 of which are keyed to match my motherboard. So in conclusion I’m only using 4 out of 12 connectors on my motherboard.
-Lian li lancool 2
