Hello I'm basically trying to build a high end computer from scratch basically (think I can salvage from my old optical DVD drives/mouse/keyboard/headset and I have an awesome monitor already!!).
Background/Needs: I'm a hardcore gamer, but I also like to run on a longer upgrade cycle than most(my computer needs to last 5yr at least). I will play my computer at bare minimums in it's later years for as long as possible until the games I want to play just don't run period (below minimum specs)...I've done this successfully in the past and I'm just barely short or too close to be comfortable for diablo 3 and I also have my eye on some upcoming FPShooters.
Reservations:
-I DON'T OVERCLOCK anything...but I might do it in the 4th/5th year if I am forced to do so. (However I think I'm going to use 1600MHz RAM rather than the listed "Memory Specifications of 1333/1060 for i7/i5 processors...I've read it's not actually 'overclocking' per se, just have to change the speed to the correct 1600MHz in BIOS, because the Motherboard&RAM I'm buying supports the 1600MHz.)
-I want Intel, not AMD.
-I like ASUS Motherboards and EVGA GeForce video cards...those have been home runs for me in the past!
-I'm waiting awhile before I worry about getting a Solid State Drive and Hard Drives are easy to replace/upgrade later...compared to other parts
CURRENTLY PLAN TO BUY:
MOBO- $200 ASUS Sabertooth P67 (5yr warranty, super durable/quality) [Better than ASUS P8Z68-V Pro??? same price]
CPU- $315 Intel Core i7-2600K (hoping it has more longevity in terms of gaming down the road than the i5-2500K)
GPU- $330 EVGA GeForce GTX 570 1280mb
RAM- $110 G.SKill Ripjaw Series 16GB(4x4gb) 1600MHz (PC3 12800) CL: 9, 1.5v, 9-9-9-24-2N timing
HDD- $55 Western Digital Caviar Black 750GB, 7200rpm, 64mb cache, SATA 6.0gb/s -Bare Drive
OS- $100 Windows 7 Home Premium
Current Total: $1110 +shipping/tax(California)...(plus a few instant savings/rebates that I didn't include)
Others I considered, non-Front runners:
-ASUS P8Z68-V Pro $200 (3yr warranty; doesn't seem like I was actually missing out on anything important)
-Intel Core i7-2500K $220 ($95 cheaper, but hoping the extra money for the i7 gives another 6+ months longevity for gaming)
-EVGA GeForce GTX 560-Ti FPB 1GB $250 (again hoping the extra $80 translates into longer before being obsolete)
Are any of my assumptions incorrect? Or do you guys think some of these would actually be better for my build? Taking into account my Needs/Reservations... Thanks!
I NEED HELP deciding on the following!!:
-CPU Fan/Heatsink!!! (need my stuff to run at safe temperatures at all times!)
-CASE!!! (old/big Antec tower is like 10yr(?) old or something, as standard/basic looking as you can get I think...was like $130 I think.)
*Basically I want a big/spacious tower that I can use for the next 10+ years...most important feature is keeping all the components inside SAFE and running COOL...dislike filmsy plastic, and water cooling...hoping for good airflow/fan action if possible. Let me know what is best/possible, prefferably under $200, but something worthy of the components I'm putting inside basically. Open to suggestions! Coolmaster, Antec, etc..??
-MISC Cooling??? What additional fans do you suggest for the case? External Cooling Devices? Anything?
-Power Supply...how many Watts are needed for all this stuff and how many watts should I actually purchase? Brands etc?
-MISC Stuff that I'm forgetting? (Planning on using onboard sound/internet)
-Or if you had something completely different in mind on any component that you think fits my Needs/Reservations and I didn't mention
THANK You all to anybody who responds and offers insight!! If you actually read all this stuff and try to help me out I will be GREATFUL!
Reservations:
