spitfire25
alright, this is seems like a simple task.. modem>router>pc/xbox360
but. i go to set up my router, follow the instrustions on the cd and then it says it cannot connect or tells me to turn my modem off and on again. so i do that and i get the same thing.
please any help.
i have a Linksys Wireless G Home Router - WRH54G
my ISP is Cogeco - im from canada.
and all im trying to do is hook up my internet through a router to give both my xbox360 and computer internet access instead of switching back and forth all the time.
thanks in advanced for any help .
g-paw
Splendid
Jan 31, 2006
4,479
Try recycling your modem. Unplug for a couple of minutes then plug it back in. While you're doing that, reset the router to the default settings, should be a button on the back. Then try to set up the network again. Precisely follow the directions, e.g., do not plug anything in until directed
