Hey all,
I just got an xfx 295x2 and installed it, but i'm getting low fps in all games. It's replacing a 2gb gtx 770 that played games nicely at 1440.
The system is a intel 5820k at stock (cpu will not bottleneck even at stock), cooled by h100i, on an msi x99 xli plus, 8 gigs crucial 2400 ram, evga g2 1000w psu. MSI after burner shows cpu is not hot (40-50 c) in games and is running at a very high percentage of gpu usage. Running on Windows 10 9926 build 64 bit.
Ram usage is rarely over 1500 mb. Games I tested with were far cry 3 which was getting 20-30 fps (got higher on 770) FFXIV, which got 60 but dipped to low 50s often, when the 770 only did it in wide open mod filled ares. FEAR 3 is around 30, when it has a solid 60 on the 770. Borderlands Pre Sequel runs the same.
When I got the card I uninstall the nvidia drivers with driver sweeper. I then did a registry cleanup with ccleaner. I rebooted and did it over just to make sure nothing was left over. After that, I installed the amd omega driver and rebooted and that's where I am now after trying some games. Any ideas on whats causing this issue? Help appreciated.
