Question Help with M.2 sockets on new motherboard ?
RenTheReaper
Great
Mar 29, 2022
170
Gtx 1660Ti
i5 9400f
Windows 11 home
Asrock b365m pro4
Hi, currently I'm transferring components from an old computer to a new motherboard and case. So my new motherboard (Asrock B365m Pro4), has 2 types of M.2 ports from what I understand. One is a so called "Ultra M.2" socket, the other being perhaps a normal M.2 socket?..
Exact wording: "Equipped with M.2 slot that supports both SATA3 6Gb/s and PCIe Gen3 x4 Ultra M.2 interface that pushes data transfer speeds up to 32Gb/s"
https://www.asrock.com/mb/intel/b365m pro4/index.asp
So I was wondering which one might be more advantageous to use? Especially for gaming.
RenTheReaper
Great
Mar 29, 2022
170
On a side note.. I am admittedly wondering which socket truly with a bit of confusion from looking at the manual and what is labeled in front of me.
Lafong
Respectable
Here is more detail from Asrock web site.
- 1 x Ultra M.2 Socket (M2_1), supports M Key type 2242/2260/2280 M.2 PCI Express module up to Gen3 x4 (32 Gb/s)**
- 1 x Ultra M.2 Socket (M2_2), supports M Key type 2242/2260/2280/22110 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s)**
If M2_2 is occupied by a SATA-type M.2 device, SATA3_0 will be disabled.
What make and model drive do you intend to use?
Apparently, M2-1 works only with a PCIe drive. M2-2 works with SATA or PCIe.
RenTheReaper
Great
Mar 29, 2022
170
I noticed the details regarding the "SATA3_0 will be disabled".
I intend on using a Toshiba M.2 NVMe SSD.
RenTheReaper
Great
Mar 29, 2022
170
I've looked up information regarding the "Ultra M.2" sockets but wondered both which socket really is the Ultra M.2 socket and which socket is better to use.
RenTheReaper
Great
Mar 29, 2022
170
Especially since I found this tadbit of information on the Ultra M.2 sockets.
RenTheReaper
Great
Mar 29, 2022
170
If I recall, the current SSD I'll use until I replace it, is a PCIe 3.0 x 2 Toshiba SSD, so would my GPU (GTX 1660Ti) be affected if I use the Ultra M.2 socket?
RenTheReaper
Great
Mar 29, 2022
170
On another side note, if this is a so called heat sink:
View: https://imgur.com/a/WqDKQaq
Does that mean I can put it over my current SSD and scren them both onto the motherboard?
Lafong
Respectable
That looks like an M.2 heatsink.
I have no idea where it came from.
It may or may not fit on your Toshiba.
It's anyone's guess how much it would help or whether it is "needed".
If you are a worrywart about temps, use it if it will fit.
