help with madden2005 no CD error Please!!
G
Guest
Guest
Archived from groups: comp.sys.ibm.pc.games.sports (More info?)
Can anyone help with my madden 2k5 problem. the game intalls OK, but it
will not play the CD when I go to run it. It keeps telling me to put the
CD in the drive, "Please insert correct CD-ROM, select OK and restart". I
have treid evrything in troubleshooting and contacted EA tech support,
with no joy. Does anyone have a solution Please. Frustrated as hell!!!!
Are you sure you are putting the number 1 disk in the drive?
Jamie
For every door that closes, A window opens.
"ozzi" <auzman3@yahoo.com> wrote in message
news:fc883f8af1bc43543e0bce6549228875@localhost.talkaboutgaming.com...
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.784 / Virus Database: 530 - Release Date: 10/27/2004
megagames.com
ozzi <auzman3@yahoo.com> wrote in message
Have you installed CloneCD on your PC ? If so, uninstall it.
I noticed that I must insert the disk in the drive I installed it. I get
the same error if I try running it from another drive. If you have more
than one drive make sure you are doing that.
