Help with making my CPU fan quieter
Crestfallen_12
Commendable
Jan 30, 2017
52
So I'm with a problem with the CPU fan(Ryzen wraith stock cooler) it's making both a vibrating noise and a clicking noise, and even after removing the fan and holding it in my hand, it's still vibrating and sounding like the fan is struggling, showing that the problem is on the fan itself and not on the way it's mounted.
I could replace it with another cooler, but I really like the looks of it and it's performance is great since i'm not doing any heavy overclock. I tried to use some lubrication of oil on it's back but it made it slightly worst, and I could not find any cheap stock coolers or amd fans to replace it either(I don't live in the US by the way) so I'm wondering if there's any way to fix it.
I never did that before, so should I sent an email to the store where I bought it asking for them to replace the stock fan? I bought it only some months ago.
That's a good idea for now.
