Question Help with massive frame spikes in games and input lag
Jan 28, 2019
12
I've had a pre built PC just over a year now and the majority of the time I have been experiencing constant random input lag on the mouse in games.
I can lock the frame rate to a level where nothing is coming close to max usage and it will still spike every 20 seconds or so. I have also noticed the constant change in mouse input seems to happen with the spikes.
I sent the PC back to be checked under warranty and it came back with everything checked and it says passed on all components.
I have reset Windows many times now and tested it barebones with nothing else installed on the PC and it still does it.
Any ideas? :/
Jan 28, 2019
12
I downloaded a single player game I have on Origin - Medal of Honour Warfighter.
The mouse is super snappy (How it should be) and no spikes or stutters. The game is locked to 60fps and runs way nicer than anything else I have played online at much higher framerates.
So my internet router could be the cause? All speed tests are fine and I've not changed any default router settings though.
Similar threads
