Help with Memory
roseey
19
HELP!!!!
I think I ordered the wrong memory for my motherboard :cry:
Can a Quad Channel Kit be used instead of a Dual Channel Kit in Asus P8Z68 Deluxe/Gen3? The MB states Channel supported: Dual Channel
G.SKILL Ripjaws X Series 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL7Q-16GBXH
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231442&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1xvzkey3chz
CORSAIR Vengeance 16GB (4 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model CML16GX3M4A1600C9B
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233198&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=15c120rsrufth
PLEASE HELP!!!!! :cry: :cry:
Quad channel can be used in dual channel boards, the only thing to 'worry' about is the speed. Quad channel was made for the Sandy Bridge E series, so it works at (usually) like 2100 speed instead of 1333 or 1600.
Hypothetically, it should 'slow itself down' to the speed your board/CPU run, but I've never seen anyone post on how well it works with LGA 1155 chips.
Also the downfall to using Quad is the timings are usually higher (like 10-11-10-27) instead of CAS 9 or CAS 8. I see the ones you got are CAS 7, it should be fine, the form factor is still correct (DDR3 240 pin).
Quad channel RAM only means that the sticks are tested to work together. Dual channel kits are sets of 2 that work together and quad channel kits are sets of 4 that work together.
Being that dual channel needs sets of 2 and a quad channel kit is just 2 sets of 2 then of course a quad channel kit will work fine in a dual channel system.
Either of those sets are fine for a sandy Bridge system since the most important thing is that the RAM be 1.5v. The DDR3 1600 stuff will be faster.
He posted links to DDR3 1333 and DDR3 1600 not DDR3 2133...........
Higher speed RAM requires higher timings. This is offset by the higher bandwidth provided by the higher speeds.
"Higher speed RAM requires higher timings. This is offset by the higher bandwidth provided by the higher speeds."
Means if I install the RAM and it okay, I will need to test the speed to make sure it is alright. The question is should I keep them or return for the correct Memory Channel. I don't want to know that 3 months from now I'll be having problems with them. Also, thanks Scottiemedic and Anort3 for your information
Read my post. Either kit you linked to is FINE for your motherboard. Listing RAM as quad channel is a marketing ploy.
Glad I could help. :)
No it does not mean anything even of the sort. It means DDR3 2133 runs at a higher cas latency than DDR3 1333. The comment was aimed at Scottiemedic.
You still did not even say what RAM you ordered exactly but either of the kits you linked to are fine for a Z68 / Sandy Bridge system.
Optimal memory for a Sandy Bridge system is 1.5v DDR3 1600 cas 9. Any kit containing 2 or 4 identical sticks.
It works at whatever speed it is rated at.....since he linked to DDR3 1333 and DDR3 1600 those kits do not magically transform into DDR3 2133. If you want DDR3 2133 you have to buy it.
You missed the point. You implied that quad channel memory runs at DDR3 2100 speeds just because it's listed as quad channel. It's still whatever speed the RAM is rated at.
Being listed as a quad channel kit is only a marketing gimmick. The sticks have been tested as identical and that's it. You could just as easily buy 4 separate identical sticks and they would work as quad channel in a quad channel motherboard.
I was not trying to be critical, just trying to make sure the info given to the OP was as correct.
I'll put in 2 RAM (2x4) first to see how my motherboard responds; if there is a problem I'll put in all of the 4 RAM. I'll be installing my PC either Thursday or Friday since I'm waiting on the DVD (Optical) Drive to arrive.
Thanks for the assistance Anort3 and Scottiemedic; I have completed building my pc and the (RAM) memory are fine. My system does not have a problem with them.
ASUS P8Z68 DELUXE/GEN3 LGA 1155 Intel Z68 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Prod [...] 6813131791
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core
http://www.newegg.com/Product/Prod [...] 6819115070sktop Processor BX80623I72600K
ARCTIC COOLING ACFZ13 92mm High Performance CPU Cooler for Intel and AMD
http://www.newegg.com/Product/Prod [...] 6835186039
Corsair Obsidian Series 650D (CC650DW-1) Black Steel structure with black brushed aluminum faceplate ATX Mid Tower Computer Case
http://www.newegg.com/Product/Prod [...] ian%20650d
http://www.newegg.com/Product/Prod [...] 6820231442
COOLER MASTER Silent Pro Gold Series RS800-80GAD3-US 800W ATX 12V v2.3 / EPS 12V v2.92 SLI Ready CrossFire Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
http://www.newegg.com/Product/Prod [...] 6817171057
OCZ Vertex Turbo OCZSSD2-1VTXT120G 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Prod [...] 6820227470
Seagate Barracuda 7200.12 ST31000528AS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Prod [...] 6822148433
Silverstone Model SST-CP09 120mm External to Internal 19 pin USB3.0 Adapter Cable
http://www.newegg.com/Product/Prod [...] 12162012le
Acer S201HLbd Black 20" 5ms LED-Backlight LCD monitor 250 cd/m2 ACM 12,000,000:1 (1000:1)
http://www.newegg.com/Product/Prod [...] 201%20hlbd
Samsung SH-B123L/RSBP Internal DVD-Writer
http://www.amazon.com/Samsung-SH-B [...] 580&sr=8-2
