Hello all,
I was wondering if someone could help me as I'm losing the will with my PC which I use for work. I seem to be experiencing sudden BSOD's (every hour or so). I had this problem last year and I thought it was being caused by the iCue software I had installed however the problems have returned and strangely enough, it seems to happen when the weather is hot as it did last year. My system shows the GPU and CPU are around 40-50C so I can't seem to pinpoint where the problem is. I have my fans going 100% including the GPU but still I get BSOD's.
My PC consists of the following components
i7 6800k (NZXT Kraken X52 AIO)
RTX 3070TI (FE)
MSI X99 Gaming Carbon Pro
4x8GB Corsair Vengeance DDR4 3200
WD Blue NVME M.2 Boot Drive
Here is the latest mini dump file. I have no idea what I'm looking at so apologies for my ignorance but any assistance would be very much appreciated.
For analysis of this file, run !analyze -v
nt!KeBugCheckEx:
fffff803`3b5fbca0 48894c2408 mov qword ptr [rsp+8],rcx ss:0018:ffffb100`4c1678f0=0000000000000124
10: kd> !analyze -v
* Bugcheck Analysis *
WHEA_UNCORRECTABLE_ERROR (124)
A fatal hardware error has occurred. Parameter 1 identifies the type of error
source that reported the error. Parameter 2 holds the address of the
nt!_WHEA_ERROR_RECORD structure that describes the error condition. Try !errrec Address of the nt!_WHEA_ERROR_RECORD structure to get more details.
Arguments:
Arg1: 0000000000000000, Machine Check Exception
Arg2: ffff9d8648c8f028, Address of the nt!_WHEA_ERROR_RECORD structure.
Arg3: 00000000be000000, High order 32-bits of the MCi_STATUS value.
Arg4: 0000000000800400, Low order 32-bits of the MCi_STATUS value.
Debugging Details:
*** Either you specified an unqualified symbol, or your debugger ***
*** doesn't have full symbol information. Unqualified symbol ***
*** resolution is turned off by default. Please either specify a ***
*** fully qualified symbol module!symbolname, or enable resolution ***
*** of unqualified symbols by typing ".symopt- 100". Note that ***
*** enabling unqualified symbol resolution with network symbol ***
*** server shares in the symbol path may cause the debugger to ***
*** appear to hang for long periods of time when an incorrect ***
*** symbol name is typed or the network symbol server is down. ***
*** For some commands to work properly, your symbol path ***
*** must point to .pdb files that have full type information. ***
*** Certain .pdb files (such as the public OS symbols) do not ***
*** contain the required information. Contact the group that ***
*** provided you with these symbols if you need this command to ***
*** work. ***
*** Type referenced: hal!_WHEA_PROCESSOR_GENERIC_ERROR_SECTION ***
*** work. ***
*** WARNING: Unable to verify checksum for win32k.sys
KEY_VALUES_STRING: 1
Key : Analysis.CPU.mSec
Value: 5031
Key : Analysis.DebugAnalysisManager
Value: Create
Key : Analysis.Elapsed.mSec
Value: 15583
Key : Analysis.IO.Other.Mb
Value: 3
Key : Analysis.IO.Read.Mb
Value: 0
Key : Analysis.IO.Write.Mb
Value: 27
Key : Analysis.Init.CPU.mSec
Value: 1125
Key : Analysis.Init.Elapsed.mSec
Value: 50152
Key : Analysis.Memory.CommitPeak.Mb
Value: 99
Key : Bugcheck.Code.DumpHeader
Value: 0x124
Key : Bugcheck.Code.Register
Value: 0x124
Key : WER.OS.Branch
Value: vb_release
Key : WER.OS.Timestamp
Value: 2019-12-06T14:06:00Z
Key : WER.OS.Version
Value: 10.0.19041.1
FILE_IN_CAB: 061223-9875-01.dmp
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P2: ffff9d8648c8f028
BUGCHECK_P3: be000000
BUGCHECK_P4: 800400
BLACKBOXBSD: 1 (!blackboxbsd)
BLACKBOXNTFS: 1 (!blackboxntfs)
BLACKBOXPNP: 1 (!blackboxpnp)
BLACKBOXWINLOGON: 1
CUSTOMER_CRASH_COUNT: 1
PROCESS_NAME: System
STACK_TEXT:
ffffb100`4c1678e8 fffff803`3b6b785a : 00000000`00000124 00000000`00000000 ffff9d86`48c8f028 00000000`be000000 : nt!KeBugCheckEx
ffffb100`4c1678f0 fffff803`3ab815b0 : 00000000`00000000 ffff9d86`48c8f028 ffff9d86`469f1360 ffff9d86`48c8f028 : nt!HalBugCheckSystem+0xca
ffffb100`4c167930 fffff803`3b7b9b3e : 00000000`00000000 ffffb100`4c1679d9 ffff9d86`48c8f028 ffff9d86`469f1360 : PSHED!PshedBugCheckSystem+0x10
ffffb100`4c167960 fffff803`3b6b9181 : ffff9d86`46902ac0 ffff9d86`46902ac0 ffff9d86`469f13b0 ffff9d86`469f1360 : nt!WheaReportHwError+0x46e
ffffb100`4c167a40 fffff803`3b6b94f3 : 00000000`0000000a ffff9d86`469f13b0 ffff9d86`469f1360 00000000`0000000a : nt!HalpMcaReportError+0xb1
ffffb100`4c167bb0 fffff803`3b6b93d0 : ffff9d86`468e37e0 00000000`00000001 00000000`00000000 00000000`00000000 : nt!HalpMceHandlerCore+0xef
ffffb100`4c167c00 fffff803`3b6b9621 : 00000000`0000000c 00000000`00000001 00000000`00000000 00000000`00000000 : nt!HalpMceHandler+0xe0
ffffb100`4c167c40 fffff803`3b6b888b : 00000000`00000000 00000000`00000000 ffffb100`4c167ed0 00000000`00000000 : nt!HalpMceHandlerWithRendezvous+0xc9
ffffb100`4c167c70 fffff803`3b6bb0d5 : ffff9d86`468e37e0 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HalpHandleMachineCheck+0x5f
ffffb100`4c167ca0 fffff803`3b710bf9 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!HalHandleMcheck+0x35
ffffb100`4c167cd0 fffff803`3b60c8ba : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiHandleMcheck+0x9
ffffb100`4c167d00 fffff803`3b60c577 : 00000000`00000000 fffff803`3b60c4ac 00000000`00000001 00000000`00000000 : nt!KxMcheckAbort+0x7a
ffffb100`4c167e40 fffff803`5581138f : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : nt!KiMcheckAbort+0x277
ffff9702`7a4bf678 00000000`00000000 : 00000000`00000000 00000000`00000000 00000000`00000000 00000000`00000000 : intelppm!MWaitIdle+0x1f
MODULE_NAME: GenuineIntel
IMAGE_NAME: GenuineIntel.sys
STACK_COMMAND: .cxr; .ecxr ; kb
FAILURE_BUCKET_ID: 0x124_0_GenuineIntel_PROCESSOR__UNKNOWN_IMAGE_GenuineIntel.sys
OS_VERSION: 10.0.19041.1
BUILDLAB_STR: vb_release
OSPLATFORM_TYPE: x64
OSNAME: Windows 10
FAILURE_ID_HASH: {5371cb52-c3d9-558e-47d4-d31c09567ca2}
Followup: MachineOwner
RTX 3070TI (FE)
nt!KeBugCheckEx:
10: kd> !analyze -v
Arguments:
Debugging Details:
*** work. ***
*** work. ***
Value: 5031
Value: Create
Value: 15583
Value: 3
Value: 0
Value: 27
Value: 1125
Value: 50152
Value: 99
Value: 0x124
Value: 0x124
Key : WER.OS.Branch
Value: vb_release
Value: 10.0.19041.1
BUGCHECK_CODE: 124
BUGCHECK_P1: 0
BUGCHECK_P4: 800400
BLACKBOXWINLOGON: 1
STACK_TEXT:
OSNAME: Windows 10
