Hi wondering if anyone can help me. I have setup a wireless extender using the actiontec adapter. The MoCa Coax light on the adapter goes green for a while but then starts to go on and off dropping the network and internet connection also. When it works its not bad, but it stops ever 20 minutes or so for around 5 minutes. It's strange. Before connecting the Actiontec extender, the Internet never ever cut out and was very reliable with consistent speed of 65mb/s down and 10mb/s up. Its just that the signal gets weak in the bedroom so figured I would try to extend it using MoCa
Setup and Stats below. The Set top boxes always work, its the internet that goes in and out. Not sure if something was done wrong. Also if you are wondering why the adapter has the coax in cable going to the STB and the TO TV going to the splitter, well it's because when I try the opposite the MoCa signal never turns solid green or get a connection, it's only when I inverted them did it work.
Any thoughts?
Thanks!
Setup
Actiontec Extender GUI
Network Monitor and Scan
Any thoughts?
Thanks!
Setup
