****Help with monitor and speakers****
arya34
15
Yes those are good speakers, they actually have better bass response than one would expect from ones that size. You get to choose which speakers you plug in so if you want to use the Bose ones just dont plug the speaker cable from the monitor in, problem solved.
You do want to look for a 1920x1200 resolution monitor but you may want to try to pick up a better know brand, i have never heard of or scene a sceptre monitor.
