Help with Monitor overclock!!!
Sep 3, 2018
I recently got monitor that i use for casual gaming of pubg. I decided to play with it a bit, and overclock the refresh rate.
I managed to overclock the refresh rate on resolution 1280x1024 from 75 hz to 105 hz, which makes significant difference when playing. But there is a problem, when i overclock my monitor anything higher than 75 hz, i get the error message on screen (frequency out of range), even though there are visuals on screen (there is no black screen), with no errors. I will post photos bellow.
I am interested does anyone know the way to bypass this error, or trick the monitor that the refresh rate is lower, so i can play with this refresh rate? This error message only blocks portion of screen when playing.
Any help would be gladly appreciated, and i haven't seen that anyone encourted this problem.
My monitor is: Fujitsu B22W-6 LED.
Here is the screen error message:
https://imgur.com/a/domRRc3
Not recommended. That "error" is there for a purpose.
However, someone else may know some workaround that is both doable and safe.
Do bear in mind that if you do manage to overclock the monitor you will probably lose any remaining warranty.
And possibly damage the monitor beyond further use.
