Help with motherboard installation?
SpicyMiller
19
I'm having a hard time installing my motherboard (I'm new to this)
I'm using the NZXT S340 case with the MSI H110m gaming motherboard & I can't figure out how to install it
Ok, I checked and your case is supposed to support the installation of a micro atx motherboard. Here is my trial by error method. Install the I/O shield into the back of the case. Place the motherboard into the case and make sure the connectors on the back of the motherboard protrude through the I/O shield. Somewhere below that motherboard you should now see some holes which line up with the pre drilled holes in the case in which your stand offs will be screwed. Let me know if this works.
Please explain further what your difficulty is in detail. Are all products new? If so you should have all screws, stand offs and instructional manuals to install the motherboard into that case. What again is the difficulty you are facing?
All of the products are new, we can't line up any of the mobo holes with the stand offs. All instructions that came with them is just a picture book without any actual instructions
Ok, now I see your problem. If you are installing a micro motherboard into a standard mid tower atx case, I am at a lost. I have never attempted such an install. If I can come back with any update, I will.
