[SOLVED] Help With MPC HC Player
ss_56
334
15
18,795
Easy way to enlarge the controls in MPC HC? I'm speaking of play button, fast forward, etc. I can't find a setting in the options. I had them large at one time but can't remember what i did. Advanced font changer maybe?
If you can't find the option to enlarge the control buttons, why not just use the keyboard to manage/manipulate the controls? When using MPC, I use the keyboard - when I'm away from my wireless multimedia remote.
Not the most convenient for me cause i'm not always holding my wireless keyboard. I do use the keyboard for volume and only just now found that i have the 'step forward' function using the arrow keys; ha, never knew that so thanks for the advice!
