Hi Guys,
I just purchased the MS-Razor Habu. However, I'm kind of confused at how to install it. I did some research online and it seems the Habu has had some major firmware-driver problems.
I have quite a few ways to install it. The manual states to go and plug the mouse in, then install the driver CD. A sticker on the cable says to install the CD drivers then plug in the Habu. Or I can install the new drivers I got off razer support. I've also heard about flashing the Habu...
Which should I do, and In what order? ( Like should I plug in Habu, then run new downloaded drivers or...)
The drivers I downloaded were version 2.12, which I believe are the newest...
Thanks for your help
Fire_Zealot
Fire_Zealot
