Question Help with MSI MPG X570 Gaming Pro Carbon wifi
power777
21
Good evening everyone, I managed to get a board described above, however I believe it will be dead, if anyone can help, I would appreciate it.
She with a ryzen 3600, weak gpu hd 5450 and a hyperx ram 8gb 3200mhz just for testing.
I tried several bios all updated through pen with nothing on the board, it then with the minimum described above, turn on the chipset fan runs at maximum, the cpu fan also heats up, the leds light up, but the gpu fan does not run and there is no image, there is always the cpu light in ezdebug on without turning off,
I don't know if what I wrote will be enough, any help will be appreciated, thanks
