Hi guys
I am going to be doing my new build over the next couple of months, running the following:
i7-4790K - watercooled
Asus Hero VII ATX
4 x 4GB 2400MHz ram
ichill GTX 980 air boss
superflower 750W leadex gold plus
I currently have two samsung 22" LED monitors -
Samsung SyncMaster S22C300HS
I am looking to get a third monitor and use the Nvidia multi display technology.
As the current monitors i have are discontinued and only available at a silly price i am having to get a different monitor all together to sit in-between the two samsungs.
My budget is up to £150 and would possibly be looking for a 23"-24" so my main central monitor is a little bigger, I will be mainly using it for gaming as well as general PC use.
My questions are as follows:
1.) will i need to match the screen size of the other monitors for a good experience?
2.) i know running a 2k or 4k monitor with two 1080p monitors is asking for trouble, but do i need the same refresh rate etc?
3.) based on the monitors i currently have and the budget i have, could you recommend a 3rd monitor?
Thanks in advance guys - Below is the Q&A requested for this thread:
1. What Is Your Country Of Origin?
The UK
2. What do you plan to do with this monitor? (ex. Games, Movie Watching, Photo Editing, etc.)
all of the above, espec gaming
3. What resolution and screen size do you want?
23"-24" but im flexible, current screen res is 1080p
4. What refresh rate do you want? (ex. 60 hz , 70 hz.)
open to recommendations
5. How much are you looking to spend?
£100 - £150
6. Brands Preferred (ex. Samsung, Acer, Asus, AOC, HP, Viewsonic, etc. )
No pref
7. Brands Not Preferred (state reason why)
no pref
8. Are You Buying More Than One Monitor?
already have two, this will join them
9. How Many Displays Can Your GPU Support Maximum? And what GPU and driver version are you using if applicable?
dont have the gcard yet but is a iChill 980 so im guessing lots of displays
10. What Port Do You Want To Connect To (ex. DVI-D, HDMI, etc).
current monitors are setup using mini DP to HDMi adapters
11. Is This Monitor A Primary Display Or A Secondary Display?
I wish this to be my primary making my current two monitors secondary
12. Is This A Secondary Display For A Laptop?
nope
Sorry for wall of text and thanks in advance!
Rich
Asus Hero VII ATX
4 x 4GB 2400MHz ram
The UK
£100 - £150
No pref
no pref
nope
Rich
