Question Help with my budget build?
R_1
Judicious
Herald
the SSD could use a swap IMHO. despite the form factor that is a SATA drive and you can get another SATA SSD for the same price at twice the capacity this for example. ( I have one of these full disclosure)
https://pcpartpicker.com/product/WGZ2FT/kingston-a400-480gb-25-solid-state-drive-sa400s37480g
I will be updating with other suggestions to lower the price.
for your consideration
PCPartPicker Part List
CPU: AMD Ryzen 7 2700 3.2 GHz 8-Core Processor ($180.89 @ OutletPC)
Motherboard: ASRock B450M-HDV R4.0 Micro ATX AM4 Motherboard ($59.99 @ Amazon)
Memory: Crucial Ballistix Sport LT 32 GB (2 x 16 GB) DDR4-3000 Memory ($129.99 @ Amazon)
Storage: Kingston A400 480 GB 2.5" Solid State Drive ($52.99 @ Amazon)
Storage: Hitachi Ultrastar 7K3000 2 TB 3.5" 7200RPM Internal Hard Drive ($39.63 @ Amazon)
Video Card: EVGA GeForce RTX 2060 6 GB XC BLACK GAMING Video Card ($279.99 @ Newegg)
Case: Thermaltake Versa H22 ATX Mid Tower Case ($33.98 @ Newegg)
Power Supply: SeaSonic FOCUS Plus Gold 550 W 80+ Gold Certified Fully Modular ATX Power Supply ($61.98 @ Newegg)
Case Fan: Cougar Turbine 120 (4-Pack) 60.4 CFM 120 mm Fan ($29.50 @ Amazon)
Keyboard: Kingston HyperX Alloy Elite RGB Wired Gaming Keyboard ($139.99 @ Amazon)
Mouse: Kingston HyperX Pulsefire FPS Pro Wired Optical Mouse ($44.99 @ Amazon)
Total: $1053.92
Generated by PCPartPicker 2019-08-20 00:20 EDT-0400
faster CPU more cores. twice the RAM. twice the SSD space.
Reactions: hunterbrady
Here is the list:
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($197.75 @ OutletPC)
Motherboard: Gigabyte B450M DS3H Micro ATX AM4 Motherboard ($69.90 @ OutletPC)
Memory: Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory ($69.99 @ Newegg)
Storage: Intel 660p Series 512 GB M.2-2280 NVME Solid State Drive ($59.99 @ Amazon)
Storage: Western Digital Caviar Blue 1 TB 3.5" 7200RPM Internal Hard Drive ($41.99 @ Newegg)
Video Card: NVIDIA GeForce RTX 2070 SUPER 8 GB Video Card ($499.99 @ Best Buy)
Case: Corsair 270R ATX Mid Tower Case ($64.99 @ Corsair)
Power Supply: SeaSonic FOCUS Plus Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($106.98 @ Newegg)
Keyboard: Cooler Master Devastator 3 Wired Gaming Keyboard With Optical Mouse ($37.99 @ Amazon)
Total: $1149.57
Generated by PCPartPicker 2019-08-20 07:30 EDT-0400
Lot better performance for same budget.
That keyboard and mouse combo is very good and satisfactory.
Better performance, way cheaper...
Type|Item|Price
CPU | AMD Ryzen 5 3600 3.6 GHz 6-Core Processor | $197.75 @ OutletPC
Motherboard | MSI B450 TOMAHAWK ATX AM4 Motherboard | $114.89 @ OutletPC
Memory | Crucial Ballistix Sport LT 16 GB (2 x 8 GB) DDR4-3200 Memory | $69.99 @ Newegg
Storage | HP EX920 512 GB M.2-2280 NVME Solid State Drive | $64.99 @ Newegg
Storage | Hitachi Ultrastar 7K3000 2 TB 3.5" 7200RPM Internal Hard Drive | $39.63 @ Amazon
Video Card | Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card | $419.99 @ Newegg
Case | Cooler Master MasterBox Lite 5 ATX Mid Tower Case | $39.99 @ Newegg
Power Supply | SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply | $79.90 @ Amazon
Keyboard | Cooler Master Devastator 3 Wired Gaming Keyboard With Optical Mouse | $37.99 @ Amazon
| Prices include shipping, taxes, rebates, and discounts |
| Total (before mail-in rebates) | $1105.12
| Mail-in rebates | -$40.00
| Total | $1065.12
| Generated by PCPartPicker 2019-08-20 08:20 EDT-0400 |
Note: Motherboard has Flash BIOS option for easy BIOS update.
Type|Item|Price
| Total | $1065.12
I think RX 5700 XT is RTX2070 equivalent in performance.
logainofhades
Userbenchmark is a trash site. Yes the HP is probably a bit faster, but only has a 3yr warranty. The 660p has 5yr warranty. Also, for a gaming rig, faster than SATA speeds, for SSD, are not really taken advantage of, by games anyway. The 5700xt is faster than a non super 2070. Some are having issues with B450 boards, and 3rd gen ryzen. A low end x570 should be much more trouble free, here. I also added a better cooler. The wraith stealth isn't horrible, but the Gammaxx 400 is far better, and should be far quieter. Should allow for better, and longer boost clocks.
CPU Cooler: Deepcool GAMMAXX 400 74.34 CFM CPU Cooler ($19.99 @ Amazon)
Motherboard: ASRock X570 Phantom Gaming 4 ATX AM4 Motherboard ($153.99 @ Amazon)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($94.89 @ OutletPC)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card ($419.99 @ Newegg)
Case: Zalman Z1 NEO ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: SeaSonic FOCUS Gold 650 W 80+ Gold Certified Semi-modular ATX Power Supply ($79.90 @ Amazon)
Total: $1124.48
Generated by PCPartPicker 2019-08-20 09:50 EDT-0400
Total: $1124.48
Userbenchmark is not accurate but its a pretty close indication of the differences.
HP is a pretty reliable brand and with SSD endurance levels, warranty should be a secondary concern to speed. SSD drives these days hardly fail on you...
https://www.wepc.com/tips/ssd-reliability/
logainofhades
A gaming rig is likely never going to come close to hitting the endurance limit, of a 660p. My 480gb sandisk ultra II was nearly 3yrs old, when I swapped it out, and was still well over 90% on its endurance life, per Sandisk's own software. Games don't make use of NVME speeds. The 660p is just so inexpensive, that it makes getting a slower SATA drive a bad idea.
Similarly its not going to hit the endurance limit of EX920. You are making the same point.
