Help with my build thanks. ( not much text )
dasp0
30
Hey, would this build run the witcher 3 @1080p and other high end / new games?
Intel core i7 4790k
msi geforce gtx 970 gaming 4G
Corsair 16gb (2x8GB) cl9 1600mhz vengeance pro
noctua nh-d15
asus z97-A
EVGA Supernova G2 750W, 80+ Gold
Yeah having extra watts just means your PSU won't run anywhere near it's maximum. That should mean it would technically last longer that a lower watt PSU that is ran at near max capacity.
The real world situation though is that it'll just be unnecessary spending, as long as the PSU you pick is good.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($219.99 @ SuperBiiz)
CPU Cooler: Corsair H100i 77.0 CFM Liquid CPU Cooler ($99.99 @ B&H)
Motherboard: EVGA Z97 FTW ATX LGA1150 Motherboard ($91.98 @ Newegg)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory ($54.89 @ OutletPC)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive ($97.89 @ OutletPC)
Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($122.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card ($316.99 @ NCIX US)
Case: Cooler Master Storm Stryker (White) ATX Full Tower Case ($152.99 @ Micro Center)
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply ($49.99 @ NCIX US)
Total: $1207.70
Generated by PCPartPicker 2015-06-17 11:44 EDT-0400
This is fine.
I know my PSU is a little bit overkill but it also ensures if I want to do some upgrades / add cooling later I guess. So, all the parts I chose fits ? Can I OC that motherboard? Not heavily maybe but CAN I overclock it?
That's one of the things im a little unsure about, the mobo
OH! and I forgot to ask, do you think / know if these parts will fit in;
Cooler master haf 912 ?
That EVGA Z97 FTW should overclock well. Here's some results of overclocking the 4770k on the same board http://www.overclockers.com/evga-z97-ftw-motherboard-review/ They got it up to 4.9Ghz, although it could've just been a lucky chip.
That Haf 912 should fit everything everything. Space for the H100 in the top, and up to 270mm gpu's (yours is 241mm).
Everything will fit easy. The Asus board is better for overclocking 8 phase power delivery instead of the 6 phase of the EVGA.
For the 912 case remove the center drive cage that will give you less restriction on the airflow.
Thanks guys for the help! You've been really helpful! I want to pick you all as the solution.
I'm actually kinda suprised that I put up some good stuff that didn't need change!
Btw, it doesn't matter that the PSU I chose ( EVGA Supernova G2 750W, 80+ Gold ) is not gonna be fully used. I mean for example; It can't hurt if my PSU have like 1000w and I only use 500? Right?
Thanks again guys!
Actually you picked a very good power supply you have enough watts to add anouther 970 to run SLI in the future if you wish.
