So I have bought a Z170-a motherboard from ASUS and they are not selling 6th gen Skylake CPU’s so is there a way I can get a Kaby lake i7 7700k CPU into my motherboard
You will need to update the BIOS on your Z170 board with a Skylake processor part then after the BIOS update drop in your Kabylake processor part. Long process, I know but that's how it should be done.
You could try but it'd be a no go since there are a lot of documented cases where you will need a Skylake processor(even if it's a Pentium grade Skylake processor) in order to update the BIOS.
Ebay would be a good spot to look or even your local Microcenter. For the latter, you could ask them to update the BIOS for you, for a small fee...? Borrow a processor from a friend? Take it to their house and update your BIOS?
Thank you btw and I was also wondering if you could send me a link or something to show me how to get the bios update thanks a lot u are being very helpful!
