www.podelis1 :
Im on a budget. Ryzen 3 1200 is a perfect budget cpu. 10606gb bottlenecks cpu. Zotac isn't a good but not the worst. And its a great budget card. 8 gb of ram is perfect for me cuz im going to play games like pubg. If i need more i still have 2 slots so i will put ut in future. Power supply isnt the worst one. Many pc experts said to take it. I can change the m.2 to ssd and take a better one not a big deal. I can always swap or add something its a future upgradable build.
Exactly, you're on a budget, something that's obvious given your target price, yet you insist on a M.2 drive, and sacrifice important parts in the process.
Just to clarify some things you're mistaken about.
1. PUBG is a very CPU intense game. The CPU works directly with the RAM to send rendering data it calculates to it for storage before sending it to the GPU to be rendered onscreen. With what RAM you have left after W10, 8GB is not enough for many of today's games.
2. Adding another RAM module later for dual channel mode is not nearly as good as getting a matched dual channel kit to begin with. In dual channel mode the modules mirror one another. It's a lot like striping in RAID configs, the modules work as a pair communicating back and forth rapidly, which is why it's important for them to be very closely matched. If you just pick two random single modules off the shelf you risk performance issues in dual channel mode, which can result in having to set the timings slower to stabilize them.
3. A GPU's VRAM amount doesn't bottleneck a CPU. It's merely a frame buffer and having more of it makes it easier on the CPU/RAM.
Lastly, if you know Zotac isn't as good, why would you even bother with it since it costs more than the 221 Euro one I suggested?
Honestly, I thought the language barrier would be the biggest problem trying to help you, but that part was easy compared to dealing with your refusal to take any of the advice
you asked for. Did it take more time than usual to configure that build due to having to translate every page, sure, but I can deal with that a lot easier than playing this back and forth game with someone whom would rather do things their own way based on very limited knowledge and a senseless itch for things he can't afford.
Sorry, this is becoming a waste of my time.
