Just bought a Sapphire Nitro+ OC 8GB RX 580 and my games will constantly crash within 1 minute to 20 minutes of gameplay. The only way to stop this from happening is to use WattMan (not afterburner) and raise the power limit from 0 to 50%. If I try to use Afterburner and raise the power limit to 50%, it will crash once, then the GPU usage will stay pinned at 100% even at the desktop, forcing me to restart my PC. The crashes without WattMan running are just black screen crashes and my fans, lights, and etc stay on. The thing is, with Wattman settings like this and my CPU at stock 3.1 - 3.4 GHZ turbo my GPU usage fluctuates non stop in 1 second intervals... Example: from 100 to 0 to 28 to 95 to 77 to 3 to 100 to 9 and etc... So I figured it could have been a CPU bottleneck issue, so I OC'd my cpu to 3.7 GHZ and the GPU usage is still all over the place and it still crashes without Wattman. Not only the GPU usage but my fan usage will drop as well as the core clock. I have 6 case fans providing enough air flow to keep everything cool inside. My GPU temps are around 55-60 C under full load of game, CPU temps are around 45-55 C under full load as well. Could this be my CPU isn't beefy enough to make the CPU do it's job?
My Specs:
Ryzen 3 1200 @ 3.7 GHZ
Corsair Vengeance LPX 2400 8GB (1x8)
EVGA 550W PSU
MSI B350M Gaming Pro MOBO
WD Blue 1TB HDD 7200rpm
Cooler Master MA410M cpu cooler
(x6) AIGO DR12 Icestorm case fans
OS: Windows 10
Edit: I previously had an MSI GTX 1050 ti installed and it ran the games without crashing and had normal GPU usage. I also tried clean unistalling drivers and reinstalled them, I also just bought Windows 10 home edition again and nothing seems to work.
My Specs:
EVGA 550W PSU
OS: Windows 10
