Question help with my gpu problem
yoyo guys i want help/advice with a problem with my GPU
My comuputer keeps crashing(randomly but especially if try to open game or something)
ive turned down the screen resolution and that helps a bit
after goin through many things like reinstalling the OS, changing the OS and changing my graphics drivers version a bunch to try and find 1 that works
ive come to the conclusion that the problem is hardware
i unplug graphics from PSU an see this
https://ibb.co/v4jGD5p
see how that one looks different
i think this is problem, probably
basically i want to ask can this fix or do i need a new GPU??
i dont even know for sure if this is the problem
my hardware is
CPU - Intel Core i5-11400F ‎2.6 GHz
Graphics card - Nvidia GeForce RTX 3050 8GB
SSD - 1TB
PSU - aerocool integrator 500W 80 plus bronze
memory - 16GB
motherboard - ASUS PRIME H510M-K
I remember those things were really bad. It's gotta go.
If a new psu doesn't work, then the damage has already been done...
thanks for the reply m8
i looked it up and ur right, that psu has a bad rep, its probably what did it
im gonna buy another
