help with my mobo selection
rishab2000
Commendable
Jun 2, 2016
100
hey guys
im thinking of a buil now
and i came up with choosing an i5 6500, gtx 1060 gaming x and a asrock h110m mobo
what im worried about is that if the pcie slots will fit the gpu cus one of them is 3.0 x16 while the other is pcie 2.0 x4 one of them is congested and doesnt look like it can let the displays of the gpu out or let it fir properly can anyone do some research anf let me know ? and another thing i like about this is that the ddr4 and ddr3 can both run on this mobo not simultaneously tho can anyone let me know which slot is for ddr4 and which one is for ddr3
mostly I just care about the pcie slot cus idk if it can fit it looks pretty weird
u fit ur gpu in 3.0 x16 not the 2.0 x4...u only fit in 2.0 x4 when u have a second card...or if u want to attach any other pcie card like wireless/sound card...
DDR3 is not recommended with skylake cpu by intel...prolonged use can damage ur chip...u shd get DDR4 to be on safer side...
read these...
http://www.tomshardware.com/answers/id-1653731/whats-difference-pcie-x16-pci-express-x16.html
http://wccftech.com/skylake-does-not-support-ddr3-damage-ddr3l-only/
its not that im going to use ddr3 ,i want to know so that i can find a dimm that can match the colour sequence ,and yes i know that i should fit the gpu in there but when i saw the mobo it look like the 3.0 has no place and look congested
did you cehck out the mobo ?
cus the spacing between the lane and the io shield is very less , so i wanted to know if thats the 2.0 or 3.0
url
thats the one im talking about
http://www.asrock.com/mb/intel/h110m%20combo-g/
can you help meout and tell me which coloured slot is for ddr4 ?
every detailed review i find is in russian and i dont understand that language
