Hello,
I need some help with my motherboard and it's WiFi.
The motherboard I'm going to be using is the "Gigabyte GA-Z170N-Gaming 5".
I'm not a tech wiz and although I've tried to find out about its WiFi, I wasn't sure what i was actually looking for.
It is not possible for me to run a cable to my room for internet. I need to know if my motherboard has on board WiFi and if not, whether to use a USB Adapter or and Internal WiFi Card. If using an internal card is better I'd also like to know if there is the right slot for it on my motherboard because one slot will be taken by my GPU.
This is my first PC Build and I'm trying not to rush into it and discover I can't even connect to the internet when i first run it.
Thank you in advance, I'm sorry if i said anything completely wrong
