[SOLVED] Help with my new build pc
Jan 31, 2019
Hi,i just build my pc these are the pc specs:
[UserBenchmarks: Game 70%, Desk 65%, Work 60%](https://www.userbenchmark.com/UserRun/14291339)
||Model|Bench
**CPU**|[AMD Ryzen 5 1600X](https://cpu.userbenchmark.com/AMD-Ryzen-5-1600X/Rating/3920)|84.2%
**GPU**|[Nvidia GTX 1060-6GB](https://gpu.userbenchmark.com/Nvidia-GTX-1060-6GB/Rating/3639)|75.4%
**SSD**|[Kingston A400 120GB](https://ssd.userbenchmark.com/SpeedTest/229920/KINGSTON-SA400S37120G)|31.6%
**HDD**|[WD Blue 1TB (2012)](https://hdd.userbenchmark.com/WD-Blue-1TB-2012/Rating/1779)|98.8%
**RAM**|[Kingston HyperX 2133 C14 1x8GB](https://ram.userbenchmark.com/SpeedTest/121782/Kingston-KHX2133C148G-1x8GB)|41.5%
**MBD**|[Gigabyte GA-AB350M-Gaming 3-CF](https://www.userbenchmark.com/System/Gigabyte-GA-AB350M-Gaming-3-CF/51417)|
I don't know why but the pc is realy slow,most of the time if i stay 1 or 2 hours on it it starts lagging and has some kind of delay in games for example if i move my mouse it moves after 1 second or lesss,my friend has a gtx 1050 ti with an intel i 8100 and he runs gta v at 100+ fps ultra settings and i can't even run it at 60,i don't know what cause this,I think it might be the ram because it's only 2133 mhz 8 gb,the ram also has the usage 70+ when playing games or browsing,i have all drivers up to date from video card to motherboard drivers.
here is the link to the pc test:https://www.userbenchmark.com/UserRun/14291339
here it is a photo of the task manager when playing video games:https://imgur.com/a/WVak5jl
i think it also might be the os but i don't really know
waiting for help
thanks
The 1x8gb stick @2133 is really going to hurt your gaming performance. If you changed it to a 2x4gb kit @3000mhz (enabling AXMP in BIOS) then you could see up to a 20 FPS increase depending on the game.
Also how much space is left on your SSD?
thanks ,other than that is there something else wrong with my pc?
thanks for the answer
