Help With My Next Upgrade.
KieranPCGamer
531
Alright guy's i am in two minds what to upgrade next
I want to spend around £600 here are my options
Custom Watercooling Loop
Or
1440p Monitor, Keyboard, Mouse ect,
Here are my spec's Now
I7 4790k
asus z97 vii formula
H100i GTX
8GB Ram Mixed sticks as i had them lying around
GTX 980Ti
120Gb SSD
500GB WD Blue
850w Seasonic PSU
Corsair 780T
BenQ RL2455HM
What do you guy's think i should do?
I was thinking that myself but just couldn't make my mind up, am thinking about getting a second 1080p monitor along with my 1440p and triple screen but just gaming on my 1440p, what mechanical keyboard do you recommend? and gaming mouse?
I recommend spending the money on the following, although you might want to pick up a 1TB WD Blue as a storage upgrade if required:
http://uk.pcpartpicker.com/list/n4rNqk
You can get the Dell S2716DG 1440p 144hz G-Sync monitor, or the XB270HU for 50 pounds extra if you want an IPS panel with the same specs, which means richer colors and better viewing angles. I've listed both, so take your pick.
The Deathadder Chroma seems to be the best value mouse in the UK, so that is listed as well.
Corsair K70 with Cherry MX Blue switches is also going for a good price. Great keyboard with solid build quality and good keycaps.
Yeah, the problem seems to be that the three cheapest MX Blue keyboards are the Corsair STRAFE and the Cooler Master CM Storm QuickFire TK, which both retail for £85, and the K70 which is only 5 pounds for expensive at £70 for better build quality and a wrist rest, which is more than worth it imo.
Strange that the K65 isn't in that cheaper range though....
