Help with my PC build, upgrade(s) advice.
Sneakyfool
Commendable
Sep 19, 2016
6
Hi, I currently have a PC which I've been using for almost 2 years now, I'll post specs below but before I do the reason I come here is I recently bought a new monitor
Asus MG279Q 27" IPS FreeSync Gaming Monitor - Link below
http://www.ebuyer.com/708721-asus-mg279q-27-ips-freesync-gaming-monitor-mg279q
Now I have and will be using this for gaming, currently play Eve online when I get time and hopefully some BF1 when it comes out shortly.
I'm hoping to play on 2560 x 1440 Resolution without suffering to much FPS drop, with the best settings I can (hopefully ultra) but I'm realistic in the fact I may have to upgrade some specs.
This is where I need advice, I want to get the most out of a decent monitor as I've been using a 24" DGM 10:80p 60hz for as long as I can remember.
I'm pretty sure most of my specs won't need upgrading that much possibly only the CPU but I'm wiling to listen to any advice on my pc
I don't really want to spend more than £200 if I can help it. However depending what I need done I can spend a few months upgrading bits and bobs.
I'm also from the UK if that helps any.
UserBenchmarks: Game 66%, Desk 52%, Work 36%
CPU: AMD FX-6350 Six-Core - 52.4%
GPU: AMD R9 290 - 81.5%
SSD: AMD 2+0 Stripe/RAID0 478GB - 64.2%
HDD: Toshiba DT01ACA200 2TB - 65.4%
USB: USB Flash Disk 2GB - 3.1%
RAM: Corsair Vengeance LP DDR3 2x8GB - 44.5%
MBD: Gigabyte GA-990XA-UD3
